OK. My AHC now works fabulously, with one possible expection. When I have the rig full loaded with gear and a hitch packer on with another 250 lbs or so on it, it will not raise into high mode. This is a problem, as I am normally only that loaded when going off road. I can raise it into high, load it and then it will stay in, but, of course, when I pull out onto the road, it returns to normal and then won't raise when I get to a trailhead.
I was thinking it was the leverage of the hitchpacker, compounding the perceived weight. As such, I thought about moving to a roof rack. However, before I make that investment, I thought I would get your input. I like the hotch packer, as everything is easy to get to and I can remove it before doing any of the more technical trails. Plus it keeps the center of gravity lower.
Anybody have a similar situation? I've probably got 800 lbs in the vehcile and another 250 on the hitch packer when this happens.
Thanks in advance.
Thanks in advance.
