I need some assistance on a weird AHC & Suspension issue on my 2001 50th Anniv. Ed., Petrol, 'matic version, 31,000 km. It started 3 weeks ago when we went into a soft and muddy reclaimed area in Low 4-wheel drive control setting which automatically made the suspension harder (as noted on the manual, in any suspension mode: AHC indicator was N height and suspension in Normal). After going back to the main road, shifted back to H gear but noticed that the LC was still riding hard but didn't mind it.
I finally noticed the next day going to work, the ride was so bumpy. Not only was it HARD, but the front height (only) has lifted as well while the dash height indicator was in Low and a blinking OFF to match! I tried asking the local Toyo. service but they could not help since I had an imported unit (local vers. has no AHC options).
I tried a number of different combinations of shifting between L & H gear, driving reverse and forward hoping a stuck sensor or something would go back to normal. At one point, it did, but the following day, it was back to hard suspension & High front/Low rear height. I noted the AHC reservoir marker has dipped by 4 lines from normal. The only way to make the ride a little softer and tolerable for the family was to take out the fuse of the AHC from the fusebox, although the unusual stance of the LC held up.
At one time, the front height went lower than the back (checked the AHC reservoir and it was about 2 lines higher than normal)... so replaced back the fuse which caused it back to its unusual setting. I'm concerned that if I continue to do this taking/replacing the fuse and driving the LC in this condition, I may further damage other parts.
Hope somebody out there can help me resolve this problem.
Thanks in advance!!
Oscar
ps... I have ordered 3 cans of AHC in preparation for any possible fixes
Thanks in advance!!
Oscar
