My problem was brake fluid in the AHC system, following advice from two toyota service managers. Killed all four spheres at around 60 k km.
And about air or nitrogen: Air consists of 78 % nitrogen.... But of course the interesting ? is: where did the bubbles come from?
Did you read your graduations yet? (takes three minutes)
Actually, I would guess that if bubbles are observed in fluid discharging from bleed valve during bleeding, it could mean:
- Air entrapment, due to air absorbed into fluid in vented reservoir, then very gradually passing into pressurized system fluid as fluid is pumped into system and released back into reservoir repeatedly, during normal system height adjustments e.g. to compensate for loads etc. Over several years of use, this could allow a significant amount of air to be absorbed by the fluid and passed into the pressurized system.
- Air could also be absorbed into fluid at the "shocks" (dampers) at each wheel, at the piston shaft-to-seal interface, despite pressurized condition of fluid at that region (due to chemical diffusion principle).
- As noted, nitrogen might diffuse from the spheres into the fluid, especially if they fail. Since it is nearly impossible to hermetically seal a liquid-gas interface like this (with either a wiping seal or a flexible membrane), nitrogen probably diffuses into the fluid at a very slow rate in any case, even when the spheres are new and in good condition.
- There might be residual air from the factory fluid evac & fill (or fill & bleed) operation. Based on what I observed in doing 2 separate fluid bleed jobs and vehicle operation between the 2, I think the system will perform adequately even with a small amount of residual air in the system, so Toyota probably specs a tolerance allowing a small amount of residual air, in the factory fill process.
I checked, and my LO-HI fluid level changes by 12 graduations. I didn't check heights, pressures, etc. first though, so who knows what that means? Other comments welcome (including any challenges to my ideas above).
