Every suspension has a sweet spot where there is minimal toe steer (alignment change with stroke). Get too far out of that zone, and there's no hope to keep alignment at bay.
That said, AHC high was never meant as a general use driving height, which is why its limited to under 20 mph. At that position, camber becomes positive, toes in, and caster is reduced. With more neutral position lift (aka sensor lift), the change in alignment in AHC high becomes more drastic, reducing its utility to a degree. Especially with the loss of droop travel if that's not addressed (
AHC Long Travel)
AHC high in the L4 Range is great as it lifts less with lower center of gravity and keeps better alignment to about 50 mph.
Big tires tricks the system to go faster so all of these speed thresholds increase about 10% with 35s for example.
To your questions, it's best to lift with moderation to keep the suspension in its sweet spot. More lift should be achieved in combination with bigger tires that actually lifts the rear axle / pumpkin for real clearance. Done this way, alignment works out great and I have just about perfect wear across my tires. It's important to understand offset plays into this too and that can exacerbate tire/shoulder wear.
For a sensor lifted LX, I would recommend a bit more negative camber, almost neutral toe, moderate caster. LXs with big tires may want caster on the lower end to keep clearance against the body mount. These alignment settings will help make alignments in AHC high better.
