My sincerest apologies as this topic has been beaten to death, but after staring at this screen for hours and being more indecisive than ever, here goes nothing. I'm doing a full front end refresh as well as a lift using new OEM Tokico's, OME 2860 springs, and my OEM torsion bars cranked to whatever will give me .5" of rake once the springs go in the rear. I have stock bumpers, travel relatively light, and spend a fair amount of time on forest service roads. I've ordered replacements for every component that moves or is made of rubber in the front end, including OEM CV axles, 555 inner and outer tie rod ends, Whiteline steering rack bushings, OEM sway bar bushings and TT extended sway bar links, a TT diff drop, lower control arm bushings, and in the last 2,000 miles I've replaced my upper and lower ball joints with 555. I've held off on ordering UCA bushings as I'm unsure what to do about UCA's in general. When all is said and done I will probably be sitting 1.5"-2" over stock in the front, and with the OEM Tokico shocks, I've read differing opinions whether or not an aftermarket UCA is really necessary. My train of thought was to put everything together, and if I can't get an alignment in spec with my OEM UCA's I would then order aftermarket. But if the consensus is that I could benefit from them based on what I am doing, and it is unlikely I will get an alignment or droop in spec, it sure would be handy to do them while I'm in there doing everything else. If I do end up going the aftermarket UCA route, I am leaning towards Dobinsons as they accept 555 ball joints and I can save some coin by swapping my lightly used 555's into them.
