aggiecruiser
Well,
After not making much progress on my pig in the past few weeks (holidays), I finally got out into the garage yesterday and got my aftermarket 2lb residual valve and proportioning valve installed. I saw several clean ideas here on Mud, but most involved cutting and modification to the main firewall brakeline for the rear circuit. Because (for me) that firewall line was purchased, and is made of stainless steel, I wanted to avoid cuting and having to re-flare that particualr line.
So, my direction was to fabricate a bracket, and three small lines that could be substituted in place for the OEM line that goes from the master cylinder to the OEM proportioning valve. My solution is below.
Now I recognize that there are a lot of opinions on what components are needed/required for the rear disc brake conversion, and this post is not meant to debate that. It is merely a postiong of some ideas to help those of you pondering this conversion. Once I get this all operational, I will be sure and post back my finding on this setup, and let you know if I have made any adjustments, (i.e. removal of components, etc.)
-Chris
-Chris
