Aftermarket Amp with Stock LX450 Head Unit
So I didn't read all of your thread but it appears you go it all sorted. :clap:
A factory EWD would have been insightful from the beginning for you.
I installed an aftermarket amplifier in place of the oem unit but in my LC not LX. I'm sure it would have been the same or similar wiring. This provided me a pure low level signal for the aftermarket amp. Some splicing and custom RCA ends was all that was needed.
The only issue I had was that the factory head unit supplied a momentary mute signal to the amplifier to prevent "power on/off thump." Nearly all aftermarket amplifiers only have power ON thump mutes built in, not power off mutes or connectivity of a separate mute signal. When I would turn off the system, I would get a thump through all of the speakers...not a good thing long term for the speakers. It would have taken more engineering to solve the issue but by no means would have it been impossible or that difficult.
To address the comments about the head unit being the key to system I strongly disagree. Amplification of the signal is the best way to improve any audio system. Great speakers can sound like s*** on poor amplification and s***ty speakers can actually sound fair on a good signal. Anyone who thinks otherwise has been feed the bimbo best buy audio installer kool-aid.
I have since broke down and bought a cheesy aftermarket head unit for the simplicity of the usb connectivity. Other than the improved ability to adjust crossover points and levels, the sound isn't dramatically different than the stock head unit on an aftermarket amp.
The factory EWD is insightful, it even shows the separate mute signal between the HU and the amp. I saw that and decided to just go with the LOC on the front channels of the factory amp for my system like Smitty did. (still tweeking with it)
As far as upgrading the speakers vs. the HU. Remember, the sound comes from the speakers, not the electronics. No amount of processing will improve rotten speakers.
You know, I actually tried to use the wires for the sub at the center console before I ended up splicing into the FR Lft. The signal was way too low...but now that you mention it, I bet it was only too low because I had it connected to the LOC! If I would have done what you did and bypassed the LOC and simply attached RCA ends, I bet that I would have been golden and would have saved a lot of time!
Fortunately I have no thump issues. I guess that my amp has a mute for both. Lucky me I guess...I love this amp.
Smitty
Btw...I fixed the text in post #20 as it was pretty messed up on the mobile viewing...it didn't look right on the standard browser either.
Smitty
Any suggestions on where I should install the tweeters up front? They are currently hiding in the dash behind the factory dash grills. They really could sound a lot better somewhere else. The question is: do I mount by the woofer in the door or should I mount on the A pillar (low or high). Which of these options would sound the best?
Thanks,
Smitty
Smitty, is the factory amp behind the factory dash small speaker by the glove box?
Yes, that is where it is. Look at post #20 in this thread and it is the first picture. It is a little hard to tell, but those wires that I have spliced into with the butt connectors are coming of the factory amp.
Best,
Smitty
I did install the tweeters on the black pilards, they made a big dfference and I have them angle to the front sides; furthermore they sound terrific!
I was planning on adding a center channel were the subwoofer is, but not sure if it would make a big difference! Time will tell!
