Hi mudders! I haven't posted in a while, because I have been tied up with non-truck related stuff, but I still log on & lurk when I have a few minutes to myself. I want to ask the resident experts who have been screwing with their AFM's how their settings are working out. Several months ago I did a 2.6 liter stroker kit from LC engineering, since then I have been playing with the tuning to see what I can come up with. I went to our FAQ & read Tim Jenkins' tuning tips, & have also looked at LC engineering tech and various other web wheeling type tech info. So far it appears to me that a very small adjustment of the AFM wheel richens the mixture quite a bit, many of the settings I have found on the internet are overkill, including LC engineering's suggestion of 3-5 teeth. Currently I am two teeth rich, and am considering going down to one tooth. For guesstimation purposes I have been running each setting for 200 miles, reading plugs, installing new ones, changing setting & repeat test. The initial setting was LC's high end of the range, 5 teeth, moving down one tooth at a time to my present setting. I started rich to avoid a potentially dangerous overly lean condition. Also in order to protect my new o2 sensor I have installed a good used one for testing purposes. I have considered that the o2 sensor could be inaccurate, and I intend to use this setting for a little while longer because I feel that I am getting close, then I'll install the new one.
I did not go with the stroker because I was unhappy with 22re performance. I had an engine on the stand that would require crank, rods, pistons & camshaft. In this case the stroker was almost economically feasible, so we chalked up the additional parts expense as necessary experimentation.
So fellow Toyotaphiles, who has been fooling with their AFM?
