Advice needed: CV Joint boot ripped
Modesto, CA
I noticed today that my CV boot is ripped. I can't say for sure but it's possible that I bought it that way about 1000 miles ago.
Should I re-boot it or just replace it? As we all know, there's a huge cost difference but I was hoping that someone with experience could lend some advice.
.....RIP Whitney
It has to be pulled to reboot or replace regardless, so you can get a look at the joint then and see if it needs to be replaced. I highly doubt that it would have to be, you'd really have to go a LONG time and run it dry of grease for any real damage to happen. Jam a finger in the tear and see how much grease is still in there.
That is rock solid advice. Will do.
What are you seeing in price diff? I was thinking about aging for mine to be done. I was suprised to see labor on reboot wasn't that far from full replacement. Either way, it was more than I will pay. I play to run mine until it Warms a bit, then I will replace.
Do you have a spare cv? If you wheel your LC then you may want a spare. Buy a new cv and a reboot kit and replace the cv then reboot the old one so you will have a spare.
For reference, I was quoted $30 for a boot kit versus $351 for a complete axle by Dan at American Toyota. Parts only and neither includes tax or shipping. YMMV.
In my area (Central Maryland) parts and labor for a complete DS and PS reboot range from $900-$1000 (three quotes, two dealer, one independent Toyota specialist). One side was about half as much (not a lot of labor overlap). Again, YMMV.
I could install two new axles myself for less than the cost for a shop to reboot them, though I am thinking about rebooting them myself. I get to learn something new, I can buy a few new tools, and I can put the savings towards "fun" things...like a Slee diff drop to correct the CV angles that likely caused my torn and leaking boots in the first place. D'oh!
Good luck.
Good luck.
Best option if you can. It can seem a little overwhelming or intimidating to just jump into it the first time. However, follow the thread in the FAQ and it is a pretty easy job.
lots of threads covering this and i went through the same predicament a few months back. I ended up rebooting, and with the right tools was able to do it myself with a lil help from a friend.
It's several hours of work just to squirt some grease and replace a rubber, but learning how may save ya on the trail one day.
