lckarl
I have decided that I will most likely not be needing this adapter so time to sell it. Hopefully it will help someone by not having to deal with the potential pitfalls of ordering it directly from the manufacturer. Some people may get this!
This adapter will allow you to use either a Cummins 6bt(12 valve) or a Cummins 4bt to a FZJ80 A343f transmission.
The adapter has never been used. I bolted it up to a Cummins 12v in the pictures to illustrate fitment.
Buyer will receive the adapter plate, flywheel, flex plate, high torque starter, and hardware.
It is possible some of the hardware might be missing or too short sort of problem. A trip to the local hardware store would solve any such problem. I only bolted up what you see in the pictures, so did not
attach torque converter or bell housing.
There is a bit of surface rust on the flywheel and flex plate as can be seen in the pictures.
Price $1850.00 Shipping is $100.00 dollars and will come in two separate boxes due to weight. Flywheel is quite heavy.
Please let me know if you have any questions.
One other thing I want to mention. Due to an oversight in the original design, part of the adapter as it is currently hits the oil pan bolts at the back of the engine. It will need to be ground down a bit or cut out to solve this issue. I wanted to mention this so it doesn't create a WTF moment down the road for the buyer.
