Accessory Belt Tensioner pulley
California
Hello, does anyone know if the AC idler pulley is the same pulley used as the Accessory Drive Belt pulley. I've been looking on line for the Accessory drive belt adjustable pulley and I only find results for the AC idler pulley.
If you have a 93+ this is the correct part for the ac tensioner: Toyota Idler Pulley for 1FZ, AC or York OBA - https://absolute-wits-end.com/toyota-idler-pulley-for-1fz-ac-or-york-oba/
Usually, the bolt is jacked up too, so you might as well replace that at the same time: Toyota Tensioner Bolt for 1FZ AC or York OBA - https://absolute-wits-end.com/toyota-tensioner-bolt-for-1fz-ac-or-york-oba/
The alternator idler (located below the alternator) is a different part.
I can only speak for the 1997 one but the alternator idler pulley is different from the idler pulley on the AC side.
