euclid
New preasure switch, condensor, expansion valve and dryer. Vacuum down, holds a vacuum OK... not great but OK. I really need to replace my high and low side long lines.
Decided to go ahead and charge it up and look for leaks.
Compressor won't kick on. Per david's post here I jumped the black wire. Compressor kicks right on and runs fine.
W/ compressor off I'm reading about 50 psi low and 70 psi high side. Didn't run the compressor long enough to get a reading there.
My first thought was that I wired the new preasure switch wrong. The new (toyota) switch was marked differently than the origional, with no indicator of how to hook it up. I just guessed, based on the marking on the switch, how to hook it up. So, thinking this may be the problem, I swaped the wires. Still no compressor.
Thoughts?
Thoughts?
