rover67
I did a search a few nights ago and bumped into the answer but i can't find it tonight... What two wires do I short on the plug to bypass the little RPM control box?
It isolates all the amp functions. You push the AC button (yellow wire) and is send power directly to the AC pump clutch (black w white wire).
You shouldn't run like this indefinitely since your AC will not cycle, it will just run & run, bad for everything in the system including how well it cools.
You can push the button in then out every 30 seconds o so every time you use it to approximate the function.
Works very well as a field fix and to help diagnose problems.
Kevin-
Any idea why the little CSV (?) switch that controls the idle up on the carb isn't receiving a signal? Also, would replacing the AC dryer improve function of the overall AC?
Thanks!!!
The above statement would be true for orfice tube type A/C system that uses a pressure switch to cycle the compressor clutch to keep pressures equalized.
BUT, our 60's use an expansion valve to do this function, and would be ok to have the compressor engaged all the time. Many cars with OEM expansion valve systems have the compressors wired to be on all the time. I currently have my 60 set up this way.
The 60's AMP box, thermistor and pressure switch are nice features.
You have the safety of not burning up the compressor if you run out of refrigerant (and oil) and someone runs the A/C on an empty system.
Your engine RPM's won't drop at idle, and if your evaporator ices up (like that will ever happen) it will disengage the compressor until it deices.
I agree. But on our exp valve system, the only times the compressor will cycle for this purpose is if the thermistor detects the evaporator is freezing up or getting too cold, or pressure switch detects incorrect pressures. That usually happens if the system is starting to get low on refrigerant or is under filled, or the exp valve is out of tolorances.FLCruiser, what about freeze protection? Dosen't cycling the compressor prevent a frozen evaporator and therefore improve cooling?
