Hi all,
i have lexus lx470 2000 i changed timing belt on time but after 30,000 km driven the timing belt was cut and the engine turned off i took it to mechanical , he told me the cause of this was one bully goes out because of bolt broken (broken because it was welding before and the gap on the oil pump was fixed to be bigger to fit the bolt) , i change TB with new set + new oil pump , to change it the mechanical opened all front down parts to take space to open the oil pan and remove the old oil pump , he took out front tires , axles , front differential and all other things down front , after fixing it the engine start smooth and everything's will and the engine still strong , but rpm dose not go over 3800 (the engine cant go over 3.8 and shaking if i try to go over this Unburned fuel sound come from exhaust and check engine light Blinks ) other problem: all ABS TRC VSC lights came <i take it to computer check and they told ABS computer need to be changed it cost to much and i don't know if i change it the RPM will go to natural 5200-5300 , i need to fix engine RPM at first its more important than ABS system
, i want to know the ABS computer control the RPM if its not working can cause this problem? and is it reprogrammed? (the mechanical told me some errors like yaw sensor ABS Steering control etc... or , is it possible that when he opened the front down parts makes damages to ABS sensors? or something needs clean. the mechanical checked it too many times and told me everything putted In the correct position.
Is it possible that wrong TB adjustment make this problem (as he told me the TB is correct) and this problem cost me too much money & time and i cant trust more mechanical s for nothing
note: i cheeked all sensors all thing are fine coils & spark plugs , crank sensor hoses ... etc
regards,,,
regards,,,
