ABS SST
CO Springs
So I was getting all my ducks
in a row regarding trying to
talk the dealer into trying the
ABS trick for bleeding the
brakes. Just spent the last 5
hours reading about this on
the net, and here's what I
learned so far... .
The ABS actuator checker
(SST) is used by a lot of
different Toyota (and Lexus )
vehicles, and not all share the
same brake set-up. It seems
the SST has different functions
depending on which vehicle it
is plugged into. Pressing a
certain button may do
different things depending on
the vehicle, the wiring harness
used, and how that harness is
hooked up. For this reason,
there are a variety of different
overlays that attach to the
front of the SST, each with
different labels corresponding
to the dial and buttons.
The available FSM scans on
the internet from different
vehicles suggest that some
vehicles use the SST when
bleeding a hydraulic booster
(GS300, 100 series LC, older
4Runner.. .), bleeding the
POWER STEERING (on the
older trucks with rear ABS),
and for checking the function
of the ABS solenoids and
pump on most other vehicles.
The problems is that the only
time it is ever mentioned for
bleeding the brakes is when a
hydraulic booster is involved,
and the SST is plugged into
the hydraulic booster/ABS
module combo in a different
manner than how it plugs into
the FZJ-80 - and the buttons
on the SST have different
functions than they do with
the 80. Any bleeding
procedure with another
vehicle is not applicable to the
FZJ-80.
However, here is what I could
figure out with how the tool is
plugged into the FZJ...
Follow along here: http://
www.sugarlump.no/cruiser/HDJ-80_S5.pdf
and here: http://
www.autoshop101.com/forms/brake11.pdf
Apparently the FZJ uses a 3-
position solenoid with no
mechanical bypass valve. If
you read the second link that
will make sense. I'm not sure
if there is only one pump/
motor or more than one. The
FZJ has 3 solenoids - one for
the rear, and one for each of
the front wheels.
You plug in the SST using the
SST wiring harnesses "C" and
"E", and use "overlay A" on
the SST. The overlay divides
the SST into two sides, Motor
and Solenoid. On the left (the
Motor part) there are two
buttons, and the top one will
run the ABS pump/motor if
you press it.
On the right side is a dial, and
you use that to select a
solenoid (LF, RF, or rear). The
"power" button on the bottom
right then energizes the
selected solenoid. When a
solenoid is energized, brake
fluid can only flow
*backward* to the Master
Cylinder via check valves
(pushed by the pump) and
cannot flow from the MC to
the wheel. Everything I read
says do NOT energize any
solenoid more than 10
seconds, and then you should
let it rest for 20 seconds in-
between. Sounds like they
might burn up.
Two things to note: The "Air
Bleed" function on the knob
apparently only applies to
purging air from the old Hilux
power steering systems. I
could find no mention of
anyone actually using that
function to bleed brake lines.
Also, the FSMs for other
vehicles that mention using
the SST to bleed hydraulic
boosters say to hold down the
power button on the solenoid
side of the SST while bleeding.
That will not work on a FZJ,
because when the power
button is held down the
solenoid is energized (ie
closed) and brake fluid will not
flow through that line.
So, bottom line is that the SST
will activate the solenoids and
pump for the FZJ ABS system.
However, we do not have an
actual procedure on how to
use this in bleeding brakes on
a FZJ. The Toyota tech will not
be able to follow the non-FZJ
FSMs on using the SST to
bleed a hydraulic booster,
because that procedure will
not work on a FZJ.
I am open to suggested
procedures (cycle solenoid on/
off while pressure bleeding,
maybe, what about the
pump?) or any corrections/
clarifications to what I wrote
above.
I think the odds of getting one
of the dealer's techs to mess
with this without explicit
instructions seem quite
dismal.... I'll likely just be cycling the ABS on ice instead.
I would not go into the dealer with the assumption that you have to instruct the mechanic or provide him with instructions on how to perform the tests or maintenance or how to use the equipment.
First of all if that was the case that would be a very huge liability issue for both the dealer and for you. What would happen if you drove away afterwards, had brake failure, killed somebody and then found that the instructions were flawed?
I think it is great they you are taking the time to research this. Use that to your advantage by asking the service manager, service writer and mechanic how they are going to handle the procedure at the time you authorize the repair. If they start giving you a bunch of BS or can't explain it properly then call them out. There are certainly resources at their disposal from the sales district or corporate offices to get the proper procedures and documentation.
This would be my second trip to the dealer. The first time they denied the existence of said SST, then said it wouldn't work, and then said they didn't have it.
Phil, I agree with what you say above, but have no faith in the dealer's interest to pursue this.
Also, this SST thing gets talked about on Mud like all someone has to do is go into the dealer and ask them to flush the brakes with the SST. Clearly that is not the case, and in another thread I asked if anyone had first-hand knowledge of the dealer using the SST. No one did.
So I guess I started this thread so I could be able to explain to the dealer how the SST could be useful in bleeding the brakes, and also to edumicate my fellow Mudders that it is not as simple as "have dealer use the tool".
I don't have my FSM in front of me, but some of what you are saying doesn't match up.
The FSM instructs on using this SST for testing the ABS system. IIRC that includes pump, not just solenoids. The SST would be rather worthless if you could not test the pump.
I think it'd be as simple as having them follow the 80's FSM ABS testing procedure in the FSM while power bleeding. That should do the trick...
[...] On the left (the
you press it. [...]
Nope, I said twice above that you CAN run the pump with the SST.
Hoosier Daddy; thanks for finding the information, is the SST available for purchase? Pricey?? Would be great to get ahold of one and document the procedure with photos.
I saw a used one on eBay yesterday for $140, but it did not have one of the required harnesses (which would be another $50 probably).
Why take it back to the dealer?
There are several Toyota dealers in the Co. Springs and Denver area, you could call around and see if any others are familiar with 80 series brakes.
You also have a well regarded Cruiser shop (Slee) in Golden.
Agreed. The local dealer is now dead to me. Just have to find time to take it somewhere else. It would burn an entire day to take it to Slee.
Hey... speaking of local resources... Robby/Powderpig has been looking for tech questions for his Toyota Trails article. This topic may be a good one for him....
Good luck with it.
Mine is going in next week for new rotors, caliper rebuilds, pads and lines. If I run into similar probs I'll report back.
Got my truck back today.
Pedal feels like it did before, which is just fine.
Mechanic used a pressure bleeder only, no cycling of the ABS.
edit - After driving my wife's car for a few days and a Armada rental I will say the pedal travel on the 80 is long. I get initial bite right after pressing the pedal but hard braking is a few inches further.
When I brought mine to the dealer they just did conventional pump hold 2 man method. I was not happy with this as it costs $95 and I already ran tons of fluid through there. As well as anouther shop after me. I still to this day trying to figure out my brake problem. I have never had so much trouble with brakes in my life. Rediculious
