ABS faults C1256, C1252
North Africa
Hi,
ABS about to die
1. The problem is intermittent, I feel the abs motor running for a long time. upnormal.
It stops for a short time and starts again. It has a short operating cycle. When you press the brake pedal, the abs motor never stops operating.
2. When the brake pedal is pressed for a long time, an alarm light and beep warning activated.
Code c1256 and c1252
So I want to rebuild the ABS unit myself. I have the diagnostic tools and good mechanical experience, as I usually repair my car myself. But before I start, I want advice from you, what most frequently cause this code 1265., and what parts to start with؟
Thank you in advance.
