So I just swapped both rear calipers out on my truck for rebuilt units & replaced all three rear brake lines. I am going to bleed all four corners normally but i was curious about the ABS system. I just had the master cylinder done and had a full bleed completed (around 500 miles before doing the rear calipers). In the master cylinder replacement thread there was some comment that the ABS system needs to be bled via tech stream. Is this only required when replacing the master cylinder or do I need to do it when I do a normal brake job too?
