1992 FJ80, stock 80A alternator. I have the FSM with wiring diagram, but am still confused...
I'm in the process of installing a second battery using a Sure Power isolator.
The stock alternator has three (3) connections. One is the condensor, small 14-16 Gauge wire, One large plug, containing the ignition switch (and batt? lines) and one large connector containing two white lines (approx 6 guage) which is held on to a stud in the alternator by a nut.
Now, the Sure Power (hereinafter "SP") instructions have the battery terminal on the back of the isolator being removed and going to the isolator. My question:
On the 1992 alternator, is the battery line in the large plug, or is it the two white 6G lines on the stud? Looking at the FSM wiring diagram, the Battery line is white.
I don't want to screw up and put the ground line to the isolator, and I'm not sure if the alternator uses the case and mount for a ground...
Anyone (Landpimp?) done this on a 1991/1992?
-H-
-H-
