Lately, the truck (kzj78) is having problems downshifting from lower speeds coming to a stop. Instead of downshifting, it will stay in a taller gear, maybe 3rd? You can then shift it into L and get moving again, then manually upshift into 2 or D and once up to speed. It seems od will also engage. This will last a few minutes and eventually the transmission will again begin upshifting and downshifting normally.
After some research, I've adjusted the throttle position cable a few times and the problem is still there.
Do you guys have any suggestions that can help me diagnose the problem? Ecu caps? Solenoids? Ect..
