Heritage 2020
As a mechanical engineer (not a lubrication engineer), I fully concur with Mr. Lake Speed Jr, in that a lot of AI myths, outdated beliefs, and personal anecdotes exist regarding oil.
Unfortunately the only empirical data that exists is that most engine wear occurs on cold engine startup where there is no dispute that 0w flows better than 5w.
From new my 3URFE has received an oil/filter change every 5k miles with Pennzoil Ultra Platinum 0w20.
At 73k miles and counting on 0w20 (plenty of hot weather summer use)—zero oil consumption, no noise, and humming along quietly (coolant flushed/filled at 60k miles with Toyota OEM).
A healthy modern liquid cooled 3URFE and cooling system does not generate oil temperatures that stress a modern synthetic 0w20.
If for some reason your engine oil temps are running hotter than what 0w20 can manage—perhaps cooling system flush/fill attention is well overdue.
NOTE1: To each their own on running 5w30 if it makes you feel happy inside.
NOTE2: Personally, if I felt the need for a higher viscosity—I’d only consider a full synthetic 0w30 every 5k miles in order to keep the 0w cold start engine protection.
