A/C vacuum pump (venturi style) question
Wile E Coyote
Out in the streets, they call it murder!
Western AZ
I've put this in tools, as it's not vehicle-specific.
Anyway, in gathering the supplies to do a moderate rehab on the cruiser's AC system, I picked up an el-cheapo venturi-style vac pump.
I tested the setup today and am questioning the adequacy of vac achieved when accounting for moderate elevation (I'm at roughly 3,700 ft). I don't think I'll see 29.95 in.Hg at 3,700 ft elevation. I believe my best case should be around 26.2 inHg. How does that sound to those in the know? Regardless, I don't think I can get there using the venturi vac pump. I saw just about 23.5 in Hg using two separate gauges. I'll be heading to the part's store to rent a real vac pump.
Edit: Forgot to mention the above tests were directly from vac pump to gauges, not on-vehicle.
I see those numbers alot. Its damn hard to get a perfect vaccum...............you will not see it anyway.
Dont beat your head over it. Its most important to get any and all moisture out and change the oil in that pump.
I fingered you'd have something to add, Crazy me boy. Thanks pal. Of course, getting all the moisture out is why I'm sweating the numbers in the first place, hehe.
Update: I picked up a loner vane-type vac pump, and am seeing about 26 in Hg straight from pump to gauges. Mo betta!
You talking about an air venturi or water venturi pump? Water venturi pumps can pump down to about 25 microns, depending on water velocity. This is good enough for A/C. Vane type oil pumps can pump below 1 micron. We use a lot of vane type pumps at work and throw them away when they can't pump below 10 because rebuilding costs more than a new one.
