Copied over from PMs for everyone else's edification:
FJKai said:
Hello. From the sounds of your response, it sounds like you got this a/c stuff down. I wanted to ask a bit more if you could. So as you may have read, I don't have the stock tach anymore, so I guess that's my problem. Where is my (60 series) amp at? I went to Spector's web site and they show a diagram of the a/c and amps, but I don't understand where is is on the vehicle. So does the 62 amp essentially plug into where the 60 amp goes, easy and simple? Any other mods I need to do or splicing or additional wiring? I apreciate your help, I'm totally stumped by this so far, your info has really helped.
-roger
Originally Posted by kevinmrowland
Hey Roger,
The tach is not the problem, but where the tach got the signal from is, your engine does not generate the same coil pulse as the 2F did so the tach, and consequently that function of the amp, do not understand the signal.
The amp is located right on the body of the AC unit under the dash, you can see it piggy-backed on there right under the glove box. It is basically a little circuit board that lets the AC know when the run, when to cycle, when to shut down.
The 62 operates a little differently than the 60 amp, instead of needing the coil signal to activate, it gets a signal from the ignition to deactivate. That means that if the 62 amp is used, your AC will work just fine, but will not turn off during startup.
The 62 amp is ALMOST a plug and play, there is one wire that needs to be pulled, I will have to check and see which one.
I have had the theory for awhile that if you actually jump the yellow wire (input) on the amp to the black wire (coil) that the pulse signal would trip, I have not tired it yet, but I am helping a Ghen with his AC issue right now and he is going to try it, if it works that will be the simplest route since all you will need is a short jumper wire. The next simplest step would be to swap in the 62 amp, there is no additional wiring need, just one wire has to be pulled, it uses the same style connector. It is just a good idea to get in the habit of shutting down the AC when you turn the vehicle off so the starter does not have to turn the AC pump when starting.
FJKai said:
I'll look into finding a 62 amp (I have a friend who works on cruisers for a living so hopefully I can find one at his place). Let me know how your friend's a/c goes, that definitely sounds easier. On the other hand, in the mean time when you remember/ find out which wire is not needed on the 62 amp let me know also. Thanks again, this is really helpful.
P.S. What do you mean by it "won't turn off when starting?" I turn off the a/c in every vehicle I have before I turn the engine off as a habit, but in this case, are you saying at key ignition "off" the power is still going to the compressor pump (or engaged)? Are you meaning to manually turn off the a/c button to kill the power to the comp. pump (since the key doesn't turn it off right?)? Then therfore are you saying anytime the a/c button is pushed in (without the key turned on) it will pwr/ engage the comp. pump? Sorry so many questions, I just want to understand completely. Thanks again!
-roger
Hey Roger,
If you are already in the habit of hitting the AC button when you shut down then you are all set. I think that most mechanically inclined individuals do so, but in land cruisers (and most other cars) the amp actually serves to shut down the AC system during startup.
The AC will not run with the car off, the clutch will not engage or anything like that, but when you go to start the car again, the AC clutch will engage at the same time the starter engages and make it a bit tougher on the starter motor.
I also checked the wiring to jog my memory on the 62 amp setup, the one wire that is an issue is actually the coil signal wire (black[not black w white]) If that wire is no longer connected to anything in your harness then it is not an issue, but to be safe you can leave everything intact, pull the black wire from the plug on your harness and insert it into the blank spot in the plug above it. That blank spot is not connected to anything in the 62 amp and wont short it out.
Then the 62 amp is a plug-n-play. We will see how Ghen does with trying to fry his amp, because it would be nice to know that a simple jumper would fix the issue.
