Hi guys,
I have an 02 LC with Nav with about 115K miles.
I need help diagnosing or at least getting a little knowledge about a noise.
I'll just summarize what I know. It started a week or so ago. There's noise coming from the engine bay and It goes up and down with the rpm's. Its a noticeable "whine" is my best description and its not happening all the time. It is not the heat shield noise, as I already had that prior to this.
I narrowed it down to the A/C. In other words, if its making the noise, it immediately stops when I hit the A/C button. So Climate control (Auto) can be on and no noise unless the A/C button is on.
Ok, so I take it to my dealer and explained all this. An hour later, he calls me back and tells me a host of recommended "services" ( Parking brake sticky, Spark Plugs, power steering flush ) for quite a lot of money and then finally he tells me they think the noise is the heat shield. $250 to fix. I reiterate again that its not the heat shield as I already knew about that. He says he'll check with the mechanic again. Calls me back 15 minutes later and says they hear a slight sound from the A/C compressor and say its about $1400 to replace ( with some lines and a switch ). I'm a little skeptical because its quite noticeable so it may be the compressor but I don't have any faith whether he's hearing the same noise.
I decline and have to eat the $132 diagnostic. He won't let me apply that to anything but the heat shield work because everything else would be considered maintenance. That will be my last time at that dealer. I don't mind paying the money if they had a clue. But they spent an hour checking the car for everything unrelated and 10 minutes to tell me they think its the compressor. Fine, rant over, incompetent dealer, I won't go back to them again.
But back to the noise. Is the A/C compressor the only possible culprit ? The A/C does work really well, btw, except for the noise. I also have to investigate whether its really a $1400 fix.
I did a lot of searching and I couldn't find much with my symptoms. Probably because there's a lot of "noise" threads. The only possible one was a thread with a (99) TSB for A/C expansion valve.
Any other thoughts ?
Thanks in advance.
Thanks in advance.
