A/C gauge reading on high and low side
PPV TEXAS
I have done a search and was not able to find anything. I purchased a set of harbor freight auto gauges and am wondering what acceptable high low readings should be at 90 degrees ambient?
Thank you in advance.
What refrigerant are we dealing with?
According to the FSM: With air set to recirc and air inlet temp 86-95 F, blower on hi, temp set to coolest and engine running at 2000rpm the low pressure side should be between 21-36 psi (0.15-0.25 MPa) and the high side should read 200-230 psi (1.37-1.57 MPa).
