A/C fan stopped working fj62
Fighting 100+ wet heat in Louisiana just got tougher.. A/C fan motor stopped working completely yesterday.. I do hear a click from the fuse panel when I turn the fan on but nothing else.. any help would be extremely appreciated
The blower motor is located under the dash - passenger side near the kick panel held up by 3 screws. First unplug the 2 wires and see if you're getting power. If yes, then you need to either disassemble and clean the motor or replace it. If no power then you need to start checking from the fuse/circuit breaker to the motor.
https://forum.ih8mud.com/60-series-wagons/491695-did-my-ac-blower-go-out.html
Read through this link - it should help you figure out what's going on.
Thank you.. Took fan off and found that plug is burnt up on resistor side.. New resistor is special order and $32.. All I need is male plug.. Anyone know where to find just plug?
Thanks
