The beating it on was not an issue since when I first tried to seat it I attempted to beat it on with what was left of the old pulley and a 24 oz. framing hammer. It barely started it and I could not remember the directions I had read several times and thought that the nut would pull it down. I wanted to be sure that it was going on 100% straight and did not want to beat the weak part of the pulley with a hammer or my improvised tool. I had thought that the nut would pull it the rest of the way in but it was not on far enough for the nut to get started on the threads.
I thought of what my grandfather used to say: "When in doubt, read the directions. Much better to read them before you skrew something up than after." I went back and read the service manual and of course they had a beautiful picture of them beating it on with a special tool. And, of course the engine was not behind the sheet metal or the frame and it was easy for them to get to everything including room to swing a hammer.
We determined that the hole in the front sheet metal (that I had heard was there for hand cranking the engine) aligns perfectly with the center of the pulley. Mine is now a bit 'out of sorts' because the front hole thru the sheet metal is larger than the rear one through the inside layer of sheet metal. I inserted a breaker bar with a huge socket on it (since I did not have the specialized tool) through the hole... The socket end of the breaker bar could be inserted through the front hole in the sheet metal but was a little too large for the rear hole. So, I inserted it from the rear leaving the socket end toward the pulley...
I put the pulley on the shaft and put the big socket on the breaker bar... Took a four pound baby sledge and persuaded it to slide on. Then I went to take the breaker out of the front of the car back thru the engine bay, the way I put it in. FAIL! The hole was not large enough to allow it to clear the pulley. It was pretty late when I came up with the above idea to get a straight on whack on the pulley and I was pretty bushed so I did not even thing about getting the tool back out.
So either I was going to have a Unicorn FJ60 with the breaker bar sticking out of the snout or I was going to have to sacrifice a good 1/2" breaker bar... Or, I was going to reshape the hole by convincing it with the baby sledge (from the rear) that the breaker bar was going to fit thru that hole. You guessed it... friendly persuasion.
