My 99 TRD is throwing two codes PO171ALT fuel trim system lean and PO125 ECT Excessive time to closed loop fuel control. The second O2 sensor reads like it isnt working. The truck only has 50k on it and everything is connected underneath and all the wires look good (nothing torn out or frayed.)
I was curious if there was a way to check and see if the O2 sensor was functiuoning without removing it. I wouldnt be surprised if the prior owner hollowed out the cat, I think this would throw a similar code. Also is top end lean out a common problem with the taco V6 (3fzE?) Any help would be great. Thanks, Mike
