No buzzer sounds.
So it doesn't have anything to do with the ebrake? like potentially a bad sensor there or needing adjustment?
Check your PMs.
I didn't see anything about in my FSM. Here are the symptom/suspect areas from the FSM that reference a brake warning light coming on.
--Brake warning light lights up (Parking brake lever released) (
note 1)
1. Brake fluid level
2. Hydraulic brake booster power supply system (Faulty)
--Brake warning light lights up and brake warning buzzer sounds (
note 2)
1. Hydraulic brake booster power supply system (Faulty)
--ABS warning light lights up (
note 3)
1. Anti - lock brake system (Faulty)
Notes 1, 3: The light may stay on for about 60 seconds after the engine is started. It is normal if it goes out after a while.
Notes 2, 3: Depressing the brake pedal repeatedly may turn on the warning light and buzzer. It is normal if the light goes off and the buzzer stops sounding after a few seconds.
Note 3: While ABS warning light is ON.
