Hi all,my 98 T100 4WD ext.cab(165k)auto,has had some bad vibriations,front end suspension/axle(it's the stock IFS,no lift).I noticed grease splattered up on the fenderwell.Tires need to be replaced soon,I put new rotors/pads on cause the rotors were shot.But it still vibes pretty bad,but not all the time.It all started when I towed my tent trailer to Pismo Beach(Surf N' Turf) in Nov.I was comming down a super steep grade before San Luis Obispo,and it was very hard to slow down.Every time I applied the brakes it shook really bad.Scared the s*** of of me,I had my two little kids w/me and they slept through the whole thing.The trailer wieght is 2700 lbs.+ our stuff.I took it real easy 4wheeling on the sand dunes/beach.The truck says it can tow 5000k,I had the braked controler setup also.So it was fine comming back,took it slow.Came back changed out the rotors/pads w/new toyota oem.Also had the tires checked for out of balance& rotated them.They are not wearing well(bad alienment?,not enough rotating?)
Anyway the grease is bothering me,do I need new seals in there.I packed the bearings good when I did the brake job.Any ideas?It's at a higher speed 55-65 mph
