Thanks to Onur "Beno" now at Nalley Toyota Stonecrest, I had parts in hand very quickly.
New Valve Cover Gasket
New Throttle Body Gasket
New Plug Gasket Seals
The intention was to get this done 2 weeks ago. Well winter is holding on strong here in DE.
So today I decided to start taking things apart.
I started by taking the Top of the filter can off. The I went to the Intake Tube. After loosening the clamps, I gave to tube a gentle twist, as I have done a couple times before....
Well this time, the tube broke at the first crease..... After careful inspection of the tear.. it was evident that there was about a 2 inch crack there for sometime. I am going to change out the vacuum line as they seem brittle.
The Plan.
1. Order new Intake tube, Vacuum line, Distributor O-ring from Beno on Monday
2. Clean and paint valve cover - Wrinkle Black
3. Clean and Paint Filter Tuna Can - Wrinkle Black
4. Replace rear Coolant line from Throttle body
5. Clean Throttle Body
NO NEED to disconnect Accel, Cruise or Trans Cables. Remove 4 bolts, 2 plugs, 2 coolant lines and lean out of the way
The Plan.
