- Location
- United States
Located in Arizona. 232k original miles. Approximately $14,000 in maintenance records since I have owned it over the past 3.5 years. Much more spent on modifications and maintenance that I don't have records for. Some of the things I have had done/replaced since owning it:
Rebuilt engine 50,000 miles ago
Recent head gasket job done with ARP head studs
Fan clutch
Thermostat
Water pump
Power steering pump
Brake master cylinder
Brake booster
Front and rear brakes both done in Dec 2016
Engine mounts
U Joints on rear and front driveshafts
Rebuilt front driveshaft
A/C compressor
Radiator
Pesky Heater Hose( PHH) replaced with Samco silicone hose and constant torque clamps
Tie rod ends
Front suspension bushings and some rear
Windshield washer pump
Hood struts
Spark Plug wires
Coolant hoses
Drive belt
Knock sensors
All the EGR equipment (permanently fixed so it will never throw a code again)
Just recently had the cooling system flushed and AC system serviced
Brand new windshield
These are the main things that I have records for. There is some minor stuff I haven't listed. I had all service done at Camelback Toyota by their very Land Cruiser savvy tech (Tom). They know me well and every time I take it in a have them look over everything and I have had everything fixed that they recommended. I just had it in a couple weeks ago.
Modifications done:
Aussie locker in rear
CDL switch
TJM Progressive 2.5" springs
TJM Caster correction bushings
OME Steering stabilizer
Icon 2.0 shocks
LCP Swaybar QD's
Swaybar drop spacers
Snorkel
Blue Sea fusebox
USB ports for charging
Extra 12V plug
Pioneer touchscreen bluetooth in-dash DVD
Rear DVD drop-down screen
Depo lights with LED's all around
Front Runner Roof Rack
5 315/75/16 BFG KO2's that are 2 years old. 4 have 9/32 tread and the 5th is never used.
Dometic CDF-11 console fridge/freezer
That's all I can think of at the moment but I'm sure I'm forgetting something. I do have the 3rd row seats, just not pictured. I also have the stock console if you don't want the fridge/freezer (I'd knock a few hundo off if you don't want it). Truck isn't perfect but it's in great shape for almost 22 years old and. The only thing I would have done (if I wasn't getting rid of it) would be to get the camber correction bearing from Slee to correct the slight camber issue. It isn't hurting anything, but with it the alignment would be perfect. As it is it pulls right when you're on a road with any crown or slope. If it's flat it isn't really noticeable. Also, the oil pressure gauge has recently stopped working all together. It was working intermittently, but has stopped working completely within the last few months. PM if you have any questions or want to see the truck.
Asking $12,500 firm
Fan clutch
Thermostat
Water pump
Power steering pump
Brake booster
Engine mounts
A/C compressor
Radiator
Tie rod ends
Hood struts
Spark Plug wires
Coolant hoses
Drive belt
Knock sensors
Modifications done:
CDL switch
Icon 2.0 shocks
LCP Swaybar QD's
Snorkel
Blue Sea fusebox
Extra 12V plug
Asking $12,500 firm
