'94 2wd 22re EFI problems
GDS
Just replace the fuel tank, old one was leaking, and put the old fuel pump back into it.
Also replace the front exhaust pipe and put a different Oxygen sensor on it from the junk yard. It ran fine for two days, but did notice a electrical smell a little. Started it at work and it ran for a few seconds, then quite. Blew the 15 amp EFI fuse under the hood twice.
Shorted it with a wire and it would start and run. Anyone have any ideas or had anything similar happen? Fuel pump bad :mad: ?
The fuel pump power lines travel through the fuel pump mount.. .if that mount is at all rusty, your short is likely on the mount. Not cheap from the dealer, but that's also your best spot to get it. I went through this in '01 and it took me about a week to track down the problem... $115 later, and it was fixed...
bkg-Thanks for the reply. Thats what I'm doing now, replacing the bracket. A company by me will repalce the fuel lines (broke one afer taking it off for the third time) for $85. Making a trip to the junk yard to see if I can find a good one too. Thanks again!
