I need some suggestions for improving the brakes on stock 93 TLC with ABS and 4-wheel disk brakes. Stock system is unsatisfactory even with a recent brake job.
tucker74 said:This is another alternative you might want to look into if you're going to go w/ new rotors -
Tucker
semlin said:I doubt the back of anyone's truck needs new rotors.
rdye said:The Land Cruiser has OEM rotors. Fronts were turned with the last brake job performed by a reputable shop. They have done work for me for years including my 92 4Runner which has had no problems.
The complaint I have is a slight pulsing when braking and not great stopping power. Once the brakes warm up a little the braking is much better but you really have to bear down when they are cold. Even for this heavy beast I think the performance should be better.
Thanks for all the suggestions. Now I have a place to start.
-rdye
-rdye
semlin said:b-wulf can't find the post but I believe people have posted in the past that even though they are DOT approved they will fatigue and burst in a way rubber won't.
