92 FJ80 V8 swap or not
Coastal GA
I've been on hiatus for quite a while after mistakenly selling my FJ40 way too early a couple decades ago, but I'm finally back after buying a rusty FJ80 that doesn't run or stop or anything else. It needs a lot of love, and parts. The dash says it's got only 121,000 miles on it but all the other parts scream that's a lie. The engine was taken apart at least 10 years ago and the head was disassembled and left outside, and it sat ever since. So, my primary goal is to get it running. Then I'll work on the details like brakes.
With the engine head in really poor condition and all the valves, springs, who knows what other parts missing, the question becomes do I toss $$ at the old 3FE to see if it's salvageable to get it running quickly or jump into a 2UZ swap. Those seem plentiful in this area and not too pricey. But I will be doing all the work myself on weekends and my neighbors don't want a nonrunner sitting in my driveway for the next 3 years while I source details. This will not be used for any crazy offroading adventures, but mostly to tow the boat to the ramp. I've read several of the 2UZ swap posts and it sounds like the major components are straightforward - the engine, trans, ECM, and wiring harness along with a lot of head scratching. Others say it's a minimum 1,000-hour job. I've rebuilt several trucks but all non-computerized. What am I missing other than lots of wiring experience? Is there a "bad" era for the 2UZ that should be avoided?
If you think you can handle a swap then LS or 2UZ is definetiely the way to go in a 3FE 80. There isn't "a lot of wiring" for either swap. You can have either swap running and driving with about four wire connections if you buy a pre-fabricated harness from any of the various vendors. You can do this! :)
i'm currently doing a GenV in my 92. not too hard although i'm doing some extra things along the way. Wiring can be premade by places like swaptime usa and then its just a few wires to hook up from there.
Not saying its the same as yanking an old 3fe and putting a new one it but the benefits are there. IMHO think LT (Gen V GM) over LS (Gen IV and III). Better engine and for the most part better trans choice also.
Either way a ls or lt is a great choice. A 2uz is a great engine but the faily low HP 230-270 isn't worth that effort in my opinion. Now a 3UR.......
Thanks for all the feedback. I'm trying to keep the momentum going on this LC in between house projects. I'm 90% convinced the 2UZ is the way to go on this one and need to make a trip to the salvage yard to check on a couple Tundras. As I dig in, the rusty bolts are winning. This weekend I pulled the trans a/c condenser and dryer, and it fell apart in my hands. I got the radiator unbolted but didn't get it out. A little research tells me the fan, fan clutch, and housing have to come out first, so that will be this week's goal to get all those removed. I assume the emissions controls can be removed (ASV, etc.) and scrapped.
I really need to pull it in the garage before the HOA gets involved, but that comes with its own challenges, like getting the e-brake to release. Baby steps.
get some car dollys from HR to throw under the rig. Makes moving it easy as pie.
I finally got through the house projects and made some progress on the engine removal this weekend. Now I have a boat anchor taking up lots of space in the garage. I need to do some cleaning of the engine bay and start painting parts of the frame while it's accessible and start shopping for an engine and transmission. Is the transfer case typically reused? Or should I try to find a 4WD Tundra for the entire drivetrain?
As you can tell, my brain is full of questions at this point. They will all be worked out as I start putting things together.
