Hello, I'm having issues with this beast and I'm at a loss. First of all please forgive me for my ignorance. I'm a simi new owner and can do basic part replacements. Troubleshooting is a whole differant area for me and left for a shop mechanic.
This beast is a straight 6, and im having issues with the truck underload. To me it feels like the truck is surging around 2k rpm. I've replaced all spark components except for distributor and coil pack. The truck needed a tune up was getting around 8-9 mpg now it's getting around 10.5. I broke my map sensor trying to take wiring harness off to clean the intake manifold. ( removed screws instead of spring clip and broke solder on the board) so I found one in Tennesee of the same year model. Had it shipped to me here in Texas. Replaced and fixed my self made problem. Then a whole new list of issues started. ( another story)
I did install the wrong plugs from what my mechanic has told me. I put in platnums when oem calls for v guard. Apparently the coil pack wont support the voltage needed for the platnums.
He also said it may be a clogged injector but wont know until he gets all plugs pulled. (Only got about an hr into it right now) Said it is running lean. Bonus is that he has worked on this machine for several yrs since he is a family friend and my dad owned it before me.
So my questions...
1. Is there an aftermarket workaround for the map sensor?
2. Any "test" that have been figured out or known? Other than unplugging the wiring harness and truck dies.
Any info would be appreciated and if you need more specs I'll find out for ya.
Thanks in advance.
So my questions...
Thanks in advance.
