2ndG, you are correct, at least on the "93. The '86 is up on the upper forty until I have more space in my work area. I was able to spend quality time on the '93 however and the fuel pressure measures at the top end of each spec, as per the FSM:
(o) Disconnect the vacuum hose from the pressure regulator and plug it closed.
(p) Measure the fuel pressure at idling.
Fuel pressure: 265–304 kPa
(2.7–3.1 kg f/cm2, 38–44 psi) (Measured 44 psi)
(q) Reconnect the vacuum hose to the pressure regulator.
(r) Measure the fuel pressure at idling.
Fuel pressure: 226–265 kPa
(2.3–2.6 kgf/cm2, 33–37 psi) (measured 38 psi)
Working on the "93 today, I was baffled by a no start condition when I had both spark and fuel pressure. Cranking speed and cadence was normal, so the timing belt was not a suspect. After a lot of wasted time testing a working ignition system, I dumped the oil, refilled the engine with fresh oil and started the engine while holding the gas pedal to the floor. The engine cranked for about 10 seconds then started with first a big puff of black smoke followed by white smoke for a few minutes. It's been a LONG time since I had to do that to start a car! My skills are a victim of these reliable machines!
I expect to uncover leaking injectors. I have my pressure gauge connected while the car sits overnight in order to view the change in rest pressure. I realize the FP may have some leakage that will allow the rest pressure to drop, but I am looking for any details that give me direction. I did not pull the spark plugs yet, but will do so after I see a dramatic loss of rest pressure overnight.
Your mention of a blocked FPR seems unlikely given the variance of the fuel pressure when the engine was running and I could stuff the throttle and watch the pressure change according to engine intake vacuum.
Given the other symptoms this car exhibits, (stalling, hesitating, hard starting, high idle speed) I believe I'll test the Volume Air Flow (VAF) meter as well. If you have any other usual suspects that show up on this forum, please let me know.
I am not sure the owner of this car will pony up for 6 or 7 injectors, along with an oil and filter change and replacement of the secondary ignition parts. If I get to see the job through I will of course post up. If not, then at least I will have brought a little more understanding to the world of
Toyota EFI understanding...
Rick
