I have been working through the 90,000 mile service in my meager amount of freetime the last couple of weeks. It was going extremely well until I about had everything off. I was had taken off the passenger timing belt cover and was working on removing the connections for the driver side timing belt cover when I broke off the long bolt that helps hold on the cover and the camshaft position sensor.
I had never come across a bolt that was stuck or crossthreaded or otherwise bound up, so I didn't know what I was feeling through the socket and ratchet as I was trying to remove it. I was quite surprised when it broke off. Unfortunately, now I know the feeling of a bolt about to break.
Here is what is left in the insert in the driver's side head:
As you can see, I purchased a couple of left hand drill bits and some PB Blaster and started working on it. What a pain. Unfortunately the bit wandered even after using a center punch and smaller bit. So now I am in a bit of trouble.
I purchased a new bolt and you can see how much is stuck in the insert in the head:
Note the amount of Loctite on that new bolt...sheesh. I will be wire brushing that off and using max a drop of Loctite.
So, I guess I have three options left and I am looking for further options, input, or advice. Options are:
1. Re-orient drill path and keep going with the left hand drill bit, hoping that the bit eventually forces the bolt to start turning out. Use a combination of PB Blaster and propane torch on it.
2. Re-orient drill path and get a nice hole in it for a bolt extractor. Not an ideal solution as it is only an M8 bolt and if I break off the extractor, option 3 is the last recourse.
3. Remove head and take it into a machine shop to get the bolt out.
I have a couple of questions. I am concerned about the head gasket or any other parts near this if I decide to use my MAP torch on it. Any thoughts about getting this super hot to try to free up the bolt?
Secondly, has anyone ever got one of these inserts out? If I could get the insert out easier than the stuck bolt, that would be a nice option. However, it looks like it is pressed in to me.
Anybody have any thoughts or advice?
