9.5ti with ARB Sahara
Bismarck, ND
If this has been discussed, please point me to it.
I'm told that my 9.5ti winch won't fit in my sahara bumper. True? Is there NO way to do it? I may be changing its color, so I might be willing to get the hole enlarged if it can save me from buying a new winch.
Is it the bumper's fault, or the vehicles?
Ihave the 9500 XP in my sahara bar
I think you need one with the seperate selnoid pack, the intergal pack won't fit(I think)
I think its the integrated solenoid thats the problem. My wife will think I'm crazy to have winches on 2 vehicles!
Ditto.
9500Xp in Sahara bar, I think you can see the problem with using the intergal pack
Ahhh, yes.
My local shop says he can cut the hole to make it fit, but I didn't know there were two "struts" that would academically decrease the strength I imagine. But if thats the only obstacle to get the 9.5 in.......
Also, if I take the 9.5 off my Rubicon - it just won't look right!
John
And another thing: I'm a bit gun shy of putting too much weight on the AHC. Adding the bumper didn't cause any problems, but another 100lbs for the winch? Is this a real fear?
I was thinking of going to synthetic line to minimize weight, but I'm guessing that it is only a difference of 10 lbs or so, huh?
John
John
Then add the weight of another battery, and a shower and pump, and a compressor and a snorkle and a rod holder and etc etc, you have to be allowed to get it up to GVM!
Yeah, I know. I thought I had read something about needing to adjust the torsion bars if too much weight is up front.
I have seen a lot of people take out the AHC, so I just assume there must be some limitations.
By the way, the 9.5 can't go on the Cruiser due to interference with the grille. Guess that solves the issue.
John
John
FWIW: I really like my 9.5XP. I used it the Saturday before last and it performed better than I had actually expected it to (plenty of reserve power for my heavy rig!)...and I mounted the solenoid pack remote and high in the engine bay...I personally think this is a better set-up than the ti solenoid being lower and generally more exposed to dirt, mud, water etc.
