88fj62 Replace bearing in front tranfer case.
bvngngnngffg I have 88 fj62 , and need to know how to remove And replace the bearing in front transfer case.
Well, there are a lot of bearings in the tcase. I assume you're talking about the one for the front output shaft. You might be able to swap the front bearing without disassembling the whole case, but I doubt it. Get a factory service manual.
If xfer case like FJ60:
- will need to disassemble case
- front output brg pushes out of nose , not guts side( after removing retaining clip).
- recommend get bearing kit & do'em all
- 2nd : Get FSM !
Pete
