No offense but your opinion is way off from TRUTH. I'm not trying to rebuttal you quoting me but you don't have the facts correct. I'm talking from EXPERIENCE here.
A balanced suspension that has as much compression as drop is VERY IMPORTANT!! PERIOD!! If you write off compression you are then transfering more motion to the frame and causing the oposite axle to compensate, ie. lifting a rear tire.
A BJ spacer add's lift to the lower arm WHILE KEEPING THE UPPER ARM IN THE SAME LOCATION. Which means you gain lift hight in the amount of spacer size AND have no loss in drop WHILE retaining compression since there is no increase in spring rate (unless you change t-bars).
A proper bracket lift DOES NOT stress steering or anything else. It addes leverage to the T-bars and on the lower arm mounts and center truss. You can fix that by welding on the trusses vs. the bolts.
The factory setup can handle a punished truck with 33" tires and a "smartly" driven truck with 35" tires.
'ntAnd now for some more retaliation!!!!!!!
I'm wait'n....................
Is it me or do you think we could start another thread with only IFS (86-95)
I think it would be cool to see different lifts, components and systems.
2"3"4"5"6"...............etc, and it could be updated to show survivabuility....?
Oh, and I just read through this thread again and missed somthing. It is NOT possible to re-clock the t-bar at the a-arm mount. It is notched to fit only one way but you can do it at the anchor end but it's not a good idea either.
Incorrect. It's very possible to re-index the torsion bar at the a-arm; I've done it. Works very well.
It is notched to fit a certain way and should not be able to be re-clocked. Only the rear anchor is this possible on. I've had both anchors off and test fited them when I was using stock t-bars with my new setup. I for one would not do this because the weak link is the anchor splines and people have broke them with just the lack of grease.
Set at aprox. 3" of lift, a full 12" of wheel travel and I have it set to 1" less drop than compression. Not to mention I still have the stock track width:
