I used a hammer and dolly to TRY to work that big dent I put in the roof when it fell off my cherry picker. I actually was able to work it from a long narrow but deep gouge to a bowl shape at least. It's slightly elevated but when I tried to work it down, it oil cans. It pops down or back up but it wont go flat. I'm going to have to try the heat and shrink thing on it.
I can see that happening. IIRC, I did one light and three heavy in the OBS bed and I tend to think it needs another coat. White seems to suck at coverage.I posted from my phone right after removing all the masking. I'm looking at these pics on my desktop now and the paint looks translucent. Almost like it needs more paint. It must be due to the LED lighting again. I sprayed a light first coat followed by two normal coats and it looks solid white in person.
When this primer dries, it looks like an egg shell surface to me.
I can't comment on this truck specifically but I've swapped several tilt columns with intermittent wipers into 89-94 generation trucks and it has always been a plug and play swap. Also, if it were me I'd be inclined to leave the harness be if for no other reason than that if there are issues after everything is back together you'll not have to wonder if something necessary was accidentally eliminated.I need some opinions here. Leave the wire harness as is? (It was running without problems when I parked it)
Or eliminate the unused wires from the engine swap while I'm at this point? IDK if I need to change any wiring to swap in the tilt column with the wiper delay yet either.
