For Sale 85 Toyota SR5 4x4-EFI-XCAB-Solid Axle-35's-LOTS OF MODS-MUST SEE
85 Toyota SR5 4x4-EFI-XCAB-Solid Axle-35's-LOTS OF MODS-NEW PICS
I have decided to sell my 85 SR5 Pickup. This truck is in excellent condition with lots of aftermarket parts. This model pickup is considered as the holy grail of toyota pickups. It came factory as a 85 SR5 4x4 with extended cab and fuel injection. The interior of this truck is flawless with no tears of stains. The only thing missing is the original center console. I have also added an inclinometer out of a SR5 4-Runner. The previous owner had painted the truck O.D. green and it did not have a bed on it when I bought it. It has a good straight, rust free bed from a 2wd truck on it right now. I also have a a nice 4wd bed that has been bobbed 12 inches that I am including with the truck(I never got around to smoothing out the weld line with bondo). The truck also has a rebuilt engine in it with around 30k on it.
Mods
Front Axle:
Trail Gear High Steer
IFS Steering Box
Trail Gear IFS Box Mounting Kit
Trail Gear Wheel Bearing Kits
Trail Gear Magnum Studs
Trail Gear Knuckle Service Kit
Trail Gear Diff Armor
Trail Gear Upper Axle Gusset
Trail Gear Creeper Gusset
Trail Gear Diff inspection plug
Trail Gear Brake Plate Eliminator
Trail Gear 5.29 Ring and Pinion Gears
Trail Gear Differential Setup Kit
Trail Gear Solid Pinion Spacer
Differential Housing studs replaced with Grade 8 bolts
Magnetic Drain Plugs
Longfield 30 Spline Axles
Longfield Hub Gears
Trail Gear Long Travel front driveshaft
Trail Gear Front Wheel Spacers
Rear Axle:
Rear Axle Replaced with wider axle from an 86 4-Runner
Rear Disc Brake Conversion
Transfer Case:
Trail Gear Dual Transfer Case Adapter(2.28 Gears in both cases)
Trail Gear Dual Transfer Case Crossmember/Skid Plate
Dr. Smash Tripple Stick Transfercase Shifter
All-Pro Transfer Case Mounted Disc Parking Brake
Suspension:
Marlin Crawler 4" front lift Springs
53" Chevy Rear Springs
Bilstien Long Travel Shocks front and rear
U-Bolt Flip Kits front and rear
Wheels and Tires:
Pit Bull Growler 35x14.50 R15
Rock Crawler 15x10 Steel Rims
Other Accesories:
Optima Red Top Battery
Daves Off Road Front winch bumper
Mile Marker 9000 lb. winch
Trail Gear Rock Sliders(not installed)
Summit brake proportioning valve
Centerforce Ceramic Clutch
New OEM Parts:
New Brake Master Cylinder
New Clutch Master Cylinder
New Clutch Slave Cylinder
New Brake Lines
New Brake pads, calipers, and rotors front and rear
There are probably parts on this truck that I forgot to list. The underside of this truck has been completely undercoated and painted. You will have a hard time finding a truck like this in better shape. Theese pictures were from when I was still working on it. I will have some better pictures in the next couple of days. This truck has never been wheeled. I have just drove it around on my farm since I finished it. Price is $7500 OBO. Feel Free to call me with any questions you may have.
More Pictures:
Green Machine pictures by pippin5267 - Photobucket
Charlie Pippin
Bristol, TN
(276)494-9070
