- Thread starter
- #21
Glad to see the truck is coming along.I think it found a good home!But whats all this talk about stacks and dbags.All diesels need a stack,its just the guys that have 5+" stacks that are dbags.What engine part are you waiting on?Just curious
Yeah, The dbags comment may have been un-called-for, but I wanted to make sure I could use the full bed, so I turned it into a tailpipe. As for the engine part, there's a story...
So I'm driving around from junkyard to junkyard trying to find some wheels when all of a sudden the cab fills with smoke that smells electrical. I pull over and lo-and-behold the positive battery alternator cable had blown. It drove home, though and I set out to replace it with some heavier gauge wire. In doing so, I removed the alternator, which meant I had to unhook the vacuum pump from it. When i moved the pump out of the way, the oil line for the pump flexed and cracked. It's braided, so I didn't notice until I got the alternator back on, started the truck, and saw oil spewing from the oil line. I ordered a factory pressure and return line set from Jerry Lemond from isuzupup.com. Truck runs great now and no leaks, at least from those two oil lines anyway.
. I was just talking to my girl the other day when we were riding in the HJ saying I should put a stack on it. She replied, "Why would you want do that?" I said, "So you can look Bad A**." I'm wondering if it would be loud right behind the cab and in that case what side do I put it on? I think it would be nice to have the intake run up beside the stack like an old cab over Mac or Peterbuilt.
) on the outer two planking boards.
