$5500.00 OBO 1985 Toyota 4 runner 5 inch lift, 35” Goodyear 75% tread, dual cases, ARB front and rear. I built this truck about 7 years ago when I lived where there were lots of rocks to crawl, I moved in mid 2007 to a place where there are no rocks to crawl so it has been used twice in four of the last six years. And maybe 20 times in the first two years. So there is little wear on the new parts. The body however is beat, that’s just part of rock crawling. I’m selling it so someone can use it for what it was built for, instead of sitting in my shop collecting dust. Here is a parts list and prices of what I paid at the time I built it. I have most if not all receipts. Truck is in Washington State
Drivetrain
Frontend
Marlin Built 8” High pinion with arb and 5.29 yukon gears…1,499.00
Longfield 27 SPLINE 4340 CHROMOLY SUPER SET……595.00
Longfield 4340 Chromoly Toyota Hub Gears ……..65.00ea = 130.00
Spindle stud kits ………………………………………………30.00
Marlin Knuckle Service Kit w/ wheel bearings……………….164.00
OTT cross over steering kit w/ tie-rod ends…………………..495.00
Marlin rebuilt IFS Steering box………………………………299.00
Frontend Total………………………………………………………………. $3212.00
Rearend
86 and newer rearend
Marlin Built 6cyl 8” with arb and 5.29 yukon gears……………………….. $1349.00
Transmission
Stock Toyota w56-A Rebuilt ($500) Marlin HD shifter seat ($8.49) ……508.49
Marlin Super heavy Duty Clutch 1600lb………………………….199.00
Marlin 0.026 step flywheel…………………………………………75.00
Transmission Total…………………………………………………………. $782.49
Transfer Case
(Front Case) Stock Toyota 1985 top shift 2.28:1
Marlin Dual Case adapter MC07…………………………………………………..369.00
(Rear Case) Marlin Built 21 spline single Transfer case with 4.7:1 Gears…675.00
Marlin Speedometer extension cable…………………………………………29.00
Core Charge (I used my stock case for crawl box)…………………………150.00
Transfer Case Total…………………………………………………………. $1223.00
Engine
Stock 22-re
Wheels and Tires
35x12.5x15 Goodyear MTR……………………………………………150.00ea= 600.00
Pro Comp Rock 15x10 Crawler Series 52 Gloss Black Powder Wheel….55.00ea=220.00
Wheels and Tires total……………………………………………………….. $820.00
Suspension
Front
Alcan/AOR Orbit-eyes 5” lift springs, 6 leaf, (all 7mm) 2”
center pin offset, 1.5” extended on tail Orbit-eyes in both ends.
Front spring cost…………………………………………………615.00
Front spring hanger for Orbit-eye w/ greaseable bolts, welded 1” forward…..69.00
This set up moves the front axle forward 3”.
Front Orbit-eye BONZ shackle w / greaseable bolts…………..89.95
Bilstein 7100 14” travel w/ remote reservoir …………….186.00ea=372.00
AOR over engine extended travel shock mount weld together kit……..169.00
AOR Front U-bolt flip kit w/ bump stops………………………………….95.00
Front Suspension total……………………………………………………… $1409.95
Rear
Alcan/AOR Orbit-eyes 5” lift springs, 5” extended, 3@7mm/5@6mm, ¾ shackle kick back, Orbit-eyes in both ends.
Rear spring cost………………………………………………………665.00
Rear spring hanger for Orbit-eye w/ greaseable bolts…………………79.00
Rear Orbit-eye shackle w / greaseable bolts……………………………89.95
Bilstein 7100 14” travel 12” body w/ remote reservoir ……186.00ea=372.00
AOR Rear U-bolt flip kit w/ bump stops……………………………..……….95.00
AOR Under body long travel shock mount…………………………….149.00
Rear Suspension total………………………………………………………….. $1449.95
Armor/Winch
Front range off-road severe use front bumper w/powder coat……… 524.00
Front range off-road Severe Use Front Frame Brace ……………39.00
Warn 9.5xp winch…………………………………………….1000.00
Redbeard off-road rock sliders …………………………………175.00
Redbeard off-road rear tube bumper w/ frame braces…………275.00
Sky Manufacturing Dual Case Mount/ Skid Plate………………200.00
All-pro off road diff guards………………………….49.00ea=98.00
Armor Total……………………………………………………………………. $2311.00
Miscellaneous
2” body lift………………………………………………….…89.00
Braided-stainless air line 8ft ………………………………….49.00
Braided-stainless air line 14ft…………………………………69.00
Adjustable prop valve bracket………………………………19.95
Braided-stainless 24” dot4 Brake lines……………………….98.00
Slee off road air manifold…………………………………….45.00
ARB air compressor………………………………………….249.00
Miscellaneous Total………………………………………………………………. $618.95
Cost of truck……………………………………………………………………... $1900.00
Over all Total…………………………………………………………. $15,076.31
This does not include any of the shipping costs or any labor (my labor) if you had this truck built it would cost over 20k. Yes the body is beat, you are welcome, that just takes the fear of putting a scratch in this beast away. You could take it out and use it to the fullest.
$5500.00 OBO Minus Wheels and Tires
dgalles25@hotmail.com
Drivetrain
Frontend
Rearend
Transmission
Transfer Case
Engine
Stock 22-re
Wheels and Tires
Suspension
Front
Rear
Armor/Winch
Miscellaneous
