For Sale 1990 Toyota Liteace turbo diesel, $3,000 OBO, Seattle, WA
Seattle, Washington United States
Outside Link
https://www.facebook.com/marketplace/item/503139959087317/?mibextid=dXMIcH
$3,000OBO. Heavy on the OBO, I'm moving out of state at the end of the month and need it gone.
Has 2ct turbo diesel, 5 speed manual, 2wd. I have owned it for almost 5 years and it has been extremely reliable and gets 30-35mpg. Took it on a 4000 mile trip in June. 138,652 Miles or 223,138KM. Timing belt and water pump and pulleys were replaced 60,000km ago.
Current problems:
-One of the shifter cables is broken. I have one on order from Japan but who knows when it will get here. Currently have a universal cable jankily rigged up that kind of works.
-Starter works 95% of the time. I have a replacement but haven't changed it due to having back surgery recently.
Work done in the last 6 months:
-Rebuilt radiator which was ungodly expensive
-upper ball joints
-new belts
-tie rods
Two of the windows are plexiglass. You can still order them from Japan but it wasn't worth it to me. Ton of spares that will come with the van including lower control arms, sway bar end links, belts, valve cover gasket, clutch set, starter, oil and fuel filters, ball joints, wheel bearings, full front break set.
Has a minimal build out in the back. Can be removed in ~5 minutes. Has 100AH battery, Diesel heater, charging ports, and some LED lights.
