For Sale 80 series interior/electronic parts
Glenwoody, Colorado
Clearing out the hoard, located in 81601
All shipping on your dime, most of this will fit in a USPS flat rate box
PM your phone # for texted pictures
Unless other wise noted all parts are from a 94 with 206K miles
  • wiper arms $10
  • pass front marker light $10 small crack about as tall as a dime
  • washer bottle $10
  • Turn signal assembly $10 (steering column)
  • Ignition assembly w/ key $10
  • engine bay wire harness w/ fuse block $20
  • Steering wheel (gray) not sure what year this is, no airbag
  • Cigarette lighter assembly $5
  • door light switches $5 ea
  • rear 1/4 marker light drivers side $5
  • Shifter boot (brown) $5
  • T-case shift knob (black) $5
  • ECT p/n 89530-60080 $5
  • cruise control unit p/n 88240-60061 $5
  • headlamp retainer p/n 85961-30050 $5
  • lamp control p/n 85965-60010
  • rear def switch $10
  • ECT switch $10
  • Hazard switch $20
  • Like
Reactions: RFB
do you have the cruise control switch/handle on the column? Also looking for the drivers door exterior handle.
See PM just sent you. Thanks.
I will take the ECU and front marker lamps.
  • front marker lights $20 small crack about as tall as a dime in passenger side
I’ll take the drivers side.
I’ll take it.
  • Grab handles (tan) $5 each shoot me a picture of the one you need so I send the right one
I’ll take all of these
  • map light/sunroof control (tan) $10
I’ll take it.
  • ECU p/n 89661-60221 $35
I’ll take it.
Paypal sent for climate control and 2 ECUs. Thanks =)
  • rear window regulators w/ motor $10 ea
  • inside door handle surrounds (brown) $5 passenger, passenger rear
I'll take both of each.
Hi Noahfecks need the following parts ship to Toronto, (Postal Code L5C3T5)
door light switches $5 ea need only 2 pcs
Also, by any chance if you have a harness for transmission, from engine bay to Tranny,
please let me know
cheers
jc
Hi Noahfecks, Do you have a power antenna please advise ship to Toronto Postal Code: L5C3T5
Thanks
jc
please let me know
cheers
jc
Thanks
jc
I would need to check into shipping to Canada
Sorry no trans harness and the power antennae sold already
