ARCHIVE 80 Series Center Console Organizer
I would speculate the stock lower hatch is the same or very close 91-94.
My 93 looks like the 95+ lids, not the 60 series. In the lower portion screws will stick through so the adhesive snaps will be needed. The upper portion has the leather padding so screws will work but may be felt if you put a lot of pressure on it or if it is worn. Try it then use washers if needed.
Maybe a picture reference is needed. If you have this console (picture) use this APU...
I will note that there are some locations where multiple different APUs can fit and the chart just shows the best fit. For example, APU-1 will fit the lower portion of my console but APU-2 is slightly longer and therefore uses more of the available space. Just check your available space with the published dimensions.
I will say I have a prov pack 80. Cloth seats, no roof rack, manual seats, ect.
@TahoeLX450 i think you called early this morning. Sorry about that, I totally faded. I was helping someone do the wiring for their winch and swap out their winch cable for synthetic. Then did the window seals on all four doors. Day just got past me.
I'll go thru the logs and see what happened.
Thanks NLXTACY got mine ordered the end of last week and CC went through fine.
Look forward to this sweet little addition and added organization!!
I'm sure you'll like it. :D
It's likely one of these from Friday.
Got mine Saturday in the mail. Top notch materials and way over packed in the box with cool thick, Whit's End, wrapping paper, drilling template, and stickers. Also, there appears to be serial numbered on the Whit's End plate so this isn't just a cordura organizer found at Pep Boys.
Some added installation notes for the LX: Removed the cover using a small socket to push out the plastic stop catches and unscrewed the lid in order to work on the bench. (The LX has two thicknesses of plastic to drill through so mine looks different than the pics above and the taller center console is one of the few differences between LX and LC.) Unscrewed the first piece, which holds on the leather cover, and drilled the first holes using the included template. Screwed it back on then drilled through the actual lid plastic being careful not to accidentally run through the foam and leather. Then took my Dremell cutting tool and cut off the sharp points (about an 1/8") off the snap screws to avoid any poking into the leather (I tried one first to make sure it threaded through). Screwed the snap screws through both pieces, used some double stick tape down the center back, and snapped it in. Filled it with small items that were loose in the console and added a couple items.
This is an excellent quality product!! I love the secret compartment to hold a credit card and some extra cash. I couldn't be happier. Great job NLXTACY!
Got mine Saturday in the mail. Top notch materials and way over packed in the box with cool thick, Wits' End, wrapping paper, drilling template, and stickers. Also, there appears to be serial numbered on the Whit's End plate so this isn't just a cordura organizer found at Pep Boys.
Quick correction in the name :flipoff2:
Yeah, I know I went over board on stuff but such as my nature in case you folks haven't figured that out about me yet :grinpimp:
Great notes!
Glad you like it :D
Here is how the 100 series APU-4 turned out in case you also happen to have a 100. :grinpimp:
img_1754-jpg.1090784
img_1758-jpg.1090785
img_1759-jpg.1090786
img_1760-jpg.1090787
img_1764-jpg.1090788
Dammit! Every thread and corner uzj100's keep coming up, Im trying to resist one in my stable.
Tell me about it. I'm not a huge fan and may just frog leap over it to the 200 but its interesting coming up with stuff for it. I have a FEM idea for it too :grinpimp:
Very nice. I would vote for fixed snaps, as adhesive is shute to fail. Glad you have sourced to the U.S. Well thought out.
Yeah the VHB I'm not all that enamored with but its better than velcro in the heat and its better than double stick tape :P
Sellouts!
Listen Joey, it's bad enough we let you Lexus people in our club. Don't go pushing your luck with a 100 or 200. Have fun at J Crew tomorrow! :flipoff2:
