For over a year I have enjoyed reading and seeing all the outstanding trailer builds in this forum. I even asked if anyone had built a trailer from a Toyota Truck, and enjoyed the responses. ‘Till now I was never able to find a truck without major rust issues.
My Dad could not pass up a 78 camo short bed truck made into a trailer for $50. He had no idea I’d been looking for this exact trailer. It will go well with my camo 77 FJ40. Happy birthday to me! The lower rear fenders have a little rust, but the rest of it is in pretty fair shape. It even has some 2’ high tube rails that are bolted on for bulky loads or parades??
Issues:
-Original axle with 5 lug hubs is still under it.
-Original springs are still under it. Springs are 2 VERY SOFT leafs with a thick straight leaf on the bottom.
Original shocks are toast.
-Dry rotted 14 inch tires
-Poor trailer conversion. The PO cut the frame at the front of the bed and welded on a full width piece of
heavy angle which the triangle frame with 2” ball mount is then welded to. It hangs mostly below the
level of the original frame.
-Short bed/conversion results in poor tongue weight/weight distribution when unloaded.
Planned Solutions:
-Buy a trailer axle with parking brake that is appropriate for my use with 6 on 5.5 hub pattern.
-Springs from a 62 I parted-out are less than an inch longer than original springs. Original springs are 2.5”
wide and the 62 springs are 2.75” wide. I have the springs, U-Bolt plates, and the shackle side frame
mounts for them. Ideas for the fixed end of the springs?
-I have access to 4 OEM 60/62 wheels with ?3.5” or 3.75”? backspacing with used 31x10.50 tires for free.
-I have access to 4 15 x 8 wagon wheels (match my 40) with 3.75” backspacing for not much.
-Re-do the trailer frame conversion.
-Add a trailer box or pickup box in front of the bed to help weight distribution.
-Mount spare to aid in better weight distribution.
The trailer will be pulled behind my 40 which has ~5” SUA lift on 35 x 12.50 x 15 MTs and my stock 100. It will be used for camping trips, hauling a canoe, and rare yard work. I don’t plan on a trailer-top-tent. A water reservoir for camp shower use would be nice. A soft or removable hard lid would also be very nice. Batteries and an AC/DC converter to run small electric items like a shower water pump would also be great.
Please give me some guidance on axle rating and width considering the available springs, wheels, and potential tires. Should I spring it over with 35x 12.50s to match the height of my 40?
What is the MUD wisdom on designing the frame? What are the geometry rules?
Thanks in advance for your contributions.
Pics to follow.
Issues:
Planned Solutions:
Pics to follow.
