Wanted 78 2F distributor body
Idaho
PO laid engine on it's side with distributor still installed. She just couldn't handle the weight.
Thanks,
JC
I can send one out today, housing with shaft and gear. The housing is good, but two of the gear teeth are chipped. Either way, you'll have to drill/drive out the gear pin to remove the shaft from the housing, then drive in a new pin when done. The OEM pins are NLA, but I have some new ones available from Toyota non-Land Cruiser distributors. That would be a better solution than hardware store roll pins.
Any other distributor parts you need?
Thanks,
JC
hey JC
, @4Cruisers / John has helped me out on SEVERAL NipponDenso Distributor Needed parts solutions jobs in my shop , for clients land cruisers i still service , he knows what he is describing here in detail for you , I can and do Vouch for him 100% , your in good hands with his advise and needed parts too ....
good luck with your repairs
hope this helps ....... :)
matt
Not sure if it would be of any use, but you’re welcome to it:
I have found a dizzy body.
Thanks everyone!
JC
