If you are looking for new brake pads and have a 75 series pickup or troopy from 95-99' you can use the pads from a 95 Toyota Tacoma (4x4 v6), they are the same.
I am not sure what year these new calipers started in but they are the ones with vanes on the outside of the caliper.
I went to replace the pads on my Troopy a while a go and found the regular land cruiser pads were not going to work. I spend some time at the parts store yesterday and found the exact match. Not sure what year they started or ended but if you ask for the 95' Taco 4x4 with v6 you will get the correct pads.
Cheers,
Michael
Cheers,
Michael
But, there is a DBA rotor that has the same dimensions that may fit, the 787SL/SR are then listed rotor for the '92 > 75 series, but the DBA-4000 4793SR/SL is the same dimensions as the troopie rotor, I may have to try them out
